Displays a list of the UPM timers on the system and some of their configuration information.
N/A.
This command displays UPM timer configuration:
show upm timers
The output of this command is similar to the following:
* BD-8808.43 # show upm timers Current Time: 2006-10-16 14:03:55 -------------------------------------------------------------------------------- UPM Profile Flags Next Execution Timer Name time -------------------------------------------------------------------------------- t1 p1 ep 2006-10-16 14:04:00(Every 10 secs) timerA -------------------------------------------------------------------------------- Flags: e - Profile is enabled, d: Profile is disabled o -Timer is non-periodic, p - Timer is periodic
This command was first available in ExtremeXOS 11.6.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
